lizziecupcakes
- London
Hi all, I know there are lots of factors that cab influence the temperature inside a house, but I just wanted to see if the following is good or bad.
It’s 9pm. The outside temperature right now is 7 degrees centigrade. My coldest room is 15 degrees centigrade. I only had the hearing on this morning for about an hour.
I’ve noticed that when I don’t have my heating on the temperature inside has usually been about 7-10 degrees higher than outside. Is this normal? Is this good?
I’ve never lived in a period property before. I grew up in a new build. Other than that, I have always lived in flats.
Thank you
Thank you
