Jon Maine
- Shepton Mallet, Somerset
I have fitted a hot water loop to each of the Ground Source heat pumps( integral hw cylinders). Simple idea comes on with the lights or a timer 22mm all the way out reducing to 15mm on the return to the tank with the bronze pump and a pressure valve fitted on the return. Non return valve fitted to stop the return pumping into the cold system (taking care not to isolate the expansion vessel of the pressurised cylinder). The expansion vessel is sized enough to take into account the pipework too. Oh, not to forget to put the pump on low speed so it does not return cold water in such a plume to the base of the tank that you prematurely get cold out of the top of the tank.
I now have a question, one of my loops is running at 3.5 bar as it should, the other 4 to 4.5 bar.
Is it probable that the expansion vessel needs re-pressurising do we think?
That is my obvious reaction.
All ideas gratefully received.
