Penners
- Suffolk, England
You're right, Greg, your flue is significantly different from ours, which is a straight run, lined and insulated flue. However, referring to your 3-monthly sweep recommendation, I venture to suggest that that's an unusual requirement based on your setup, rather than a typical one.Greg.Hobson said:ours are unlined, stone chimneys, all the way to the top, one with a horizontal run of about 10 foot (I know, what were they thinking?) before a right-angle bend into the run to the top. Neither upward run is absolutely vertical, which also helps to trap lots of potential chimney fire fuel on the ledges.
