Cloudscape
- Mid-Wales
Here's a picture of the range that currently occupies the large inglenook fireplace (the best looking, oldest and most interesting fireplace in the house).
The range is, as far as we know, a Coalbrookdale one, from the mid-to-late 1800s. (This pic was taken before we bought the house.)
The sides of the central grate have been replaced, presumably they were just kn*ckered. The replacement sheet iron is also kn*ckered and the firebrick lining needs replacing. At the moment, you can only build a small fire at the bottom of the grate.
The casing is cracked in a couple of places round the oven, but otherwise, the range is in quite nice condition.
So far so good.
But this range is hooked up to a back boiler. If you look just above the firebox, there's a hole in the firebricks. This is a rear flue. There's another slot at the back/bottom of the firebox. If you leave these holes open, the fire roars like a jet engine and flames are drawn out backwards. You can see a large air-intake hole under the firebox.
I found old diagrams of how these early back-boiler ranges worked, and this rear flue seems correct.
The upper cowl is adjustable and is an open flue. Smoke goes up here (when the chimney is warm).
The main thing is - you can light a roaring fire (wood and/or coal) and virtually no heat is given out into the room. If you block the rear flue holes, the fire acts like a normal fire, but you still don't feel any warmth from the fire unless you're about two feet from it.
I was surprised that the casing of the range never heats up. After a few hours, you can put your hand on top of the oven (the left hand section) and it's barely warm. I don't understand how the oven was heated. It stays cool. The right-hand side appears to be a 'sham'. It's just a hollow box, with an openable top. This also stays cool.
Behind this range, on the other side of the chimney, is an old Rayburn, which also has a back boiler. If I ever replace the Rayburn, I'd still like a solid-fuel option - and probably the back boiler too.
But I don't know what to do about this range. It occupies just under half the width of the fireplace (the sides are currently filled with brick).
I really don't feel I could remove it. The house is listed and I like the look of the range. But I also need some room heating to come from the fireplace. I'd like a wood stove (possible with back-boiler option) or firebox.
I'm stuck between wanting to keep the range (somehow) and having an efficient fireplace.
What would you do?
So far so good.
What would you do?
