Table 1.1b is per building based on two people in the first bedroom and 1 person in each additional bedroom. If more people use the property than an extra 4l/s is added per extra person.
"European CEN Standards now define air quality and specify ventilation ranges that are needed to achieve these Standards. High air quality requires ventilation in the range of 15 - 25 L/s for each occupant present in a space. . . . . Substantial research dating back over 100 years has shown that ventilation rates at less than 8 L/s per person are inadequate. The CEN values largely confirm this."
It would be ironic if we're storing up health problems by limiting ventilation in our homes for the sake of energy efficiency. I wonder how effective those 'whole house' heat recovery systems are in practice? Would they actually reduce heat loss or would they increase ventilation for the same (or less?) heat loss?
A survey of the homes of top environmentalists has found they leak energy
http://www.timesonline.co.uk/tol/news/environment/article5734082.ece
In my case, The CO approved draft sealing of the windows, but when the BC inspector came, he said he was often against it as he was seeing loads of serious problems in historic buildings from draft sealing, especially when done in conjunction with wall insulation. Terrible problems with mould and condensation. It seems that insulating prevails over ventilation. I have plenty of other forms of ventilation, such as chimneys, floorboards etc, so I shouldn't have a problem.
The draft sealing has mane an incredible improvement. Windows no longer knock in the wind, less noise from outside and obviously, less draft.
