Jon Maine
- Shepton Mallet, Somerset
The japanese trowels come into their own on things like curved soffits on spiral stairs, I just have a 14" marshaltown that is now around 20 years old and nicely broken in for areas.( hard handle though so gets a bit tough if used for extended periods)
It does appear from the undulating finish on some of the existing remnants that they polished the original topcoat with a small tool in a repetitive P shape sweeping motion about 4" high with a 2" circular motion, this was a technique I had a play with when I used a bit of neat putty for top coat as an experiment and it worked well ( although it shrank and cracked a bit as you would expect). I tried this because much of the original top coat appeared to just be chalky with no visible aggregate. However needless to say we use for around a 1-1 topcoat for the majority of work anyway. Also i found if you get the suction right in around 3 hours it can be polished as if it were a gypsum plaster setting. We did find in places where the suction had varied small chunks were polished more and it was trickier to get an even coat of distemper to cover.
The 16" would just kill me though. 14" gets a bit much sometimes.
I also have a small wooden japanese laying on float which is nice to use. Although I seem to have no problem using the Marshaltown for most things with a leaf tool and the japanese for finer or shaped work.
As for a sprayer we tend to have a good quality sprayhead on a quality hose pipe as it is far less messing about when you have lots to do.
