Bitstreams
- Buckinghamshire
Advice needed urgently..
I'm having the devils own job lime plastering. I'm replacing concrete tanking on a rubble-stone wall (with some brick bits) with a lime plaster. The main coats have gone on fairly well I think but I'm having a real problem getting a good finish with the top coat. The problem seems to be that the walls aren't flat - they're flatter than they were but there are undulations generally. In trying to get a smooth finish the ends of the plasterers trowl thing (you can tell I'm a beginner) cuts in and ruins the edges of the finish.
It's nowhere near as smooth and even as a gypsum plaster wall done by a professional plasterer.
I keep changing my mind from - "it's ok - it looks cottagy" to "time to ring a real plasterer and get it done properly".
I don't like the idea of the latter, because I'm supposed to be renovating this house, not just opening my chequebook and getting someone else to do it.
Advice please - this is supposed to be a 'plastering' weekend.
Simon
Simon
