Nigel Watts
- London N7
I have finally started on the paper hanging in my living room. Against all advice I am hanging the stuff myself. It is a bespoke batch (£150 a roll), and I am a little tight on quantity, so a single mistake could ruin the entire hang. Added to which the pattern repeat only gives me only 3/4 inch of leeway at the start and end of each drop. No pressure then ....
So far, so good however. I am being forced to work carefully and concentrate to avoid errors - no bad thing. The paper is a joy to handle. I am using ready made tub paste for the first time. This is much stiffer than the normal powdered paste you mix yourself, which means it needs a lot of effort to brush out, but there is much less danger of of it oozing out. I have got some little bits of paste on the front of the paper but it has washed off, apparently without staining.
The paper is a dark green. The biggest problem so far is that the whitness of the edges of the paper can be seen in some places. I initially tried pre-colouring the edges of the roll with a green wax crayon, but am now using black to get more oomph. This is now working better. I reckon some careful touch up could be possible later (with indian ink plus a fine sable paintbrush?).
The one thing I have yet to find a way of avoiding is slight tears at the corners, for example when going round a door frame or mantlepiece. Cutting the wet paper with a knife, as recommended in one of my books, was not a good idea as it tears the surface, so scissors are the only safe cutting option.
Any further hints?
Any further hints?
