Inspector John
With or without pepperoni? :wink:
From what I've read I think they are like any other wood burner to get going. They say not to build externally to a property because of that reason but I do like the idea of charging the firebox for around 2 hours (About 4 loads of firewood) at a fierce heat then I believe (correct me if I'm wrong), after it's down to the ashes you close of the flue.
The heat radiates out all day (I'm sure I read the temperature output (The masonry) was around 110 C) Supposed to last around 16 hrs to 24 hrs. Maybe expensive though to have one built. There's hundreds of different facades styles, you can have a SS back boiler installed. could also pipe excess heat to underground storage or to where the heat pump pipes are located
Much more efficient than a wood burner. Doesn't soot or tar up and there's a bread oven to boot...
Well anyway when I've finished the barn conversion (that's if I ever get started) I think I will build one.
Canada ,the States and most Europe use them except UK and France (Pass, perhaps it never gets cold enough to justify the cost)
Here's some pics of them building a masonry heater http://mha-net.org/docs/v8n2/wildac08f.htm There are different designs
