Zebra
- St Albans, Hertfordshire
Now there's a challenge.Cocoa said:I am pushing the boundaries on just how many jumpers and socks it is possible to wear at any one time.
Cocoa, would it be possible to just lay the pipework whilst the floor is up, leaving it capped off and accessible beneath short, easy-to-lift-again boards at the radiator positions; leave the two ends of the pipework accessible at your likely boiler location and take it from there, making your decision before you splash out on radiators and a boiler? You could get some plumbers round for a quote and sound them out about whether your chosen boiler location is suitable, if necessary. If you use plastic pipe and pushfit connections then you could DIY this stage, and the pipe isn't expensive, although clearly that depends on whether your house is big. You could even DIY the radiator install, and the plumber would just connect up the boiler as if it were an existing system. That's my plan anyway.
I've just spent my second winter in the house without central heating, and although it hasn't had a proper road test without, because I've had a lot of drafts (doors that don't fit), and no loft insulation (no ceiling yet..), so I haven't really seen whether it would be livable without, but I am planning to install central heating.
