You can buy ready kilned sand - mainly used for grouting in concrete paving blocks. Would that be suitable, Biff?Gervase said:Use the finest sand you can get - I seive soft building sand - and make sure it's bone dry. To make sure, put it in a Pyrex dish and give it an hour in a slow oven to get rid of any water.
Or, if you're pressed for time, just dig your fingernail into your head.biffvernon said:Wood is hard. Try hitting your head with a piece.
Wood is soft. Try digging you fingernail into a piece.
Do you have any indication of what the mix of that mastic mortar is?Craig said:The mastic mortar around my windows seems to have lasted a century or two.
Some folk have just got too much money to spend.You can buy ready kilned sand
I don't suppose it makes very much difference. The boiled might set a bit faster.Which linseed oil do you use, boiled or raw?
