Hi
Greetings to everyone who's made it over onto the new format forum so far.
I'm (trying) to repair my attic floor (softwood, tongue and groove boards) and am wondering whether to screw the boards down or use nails (cut brads)?
Using screws would avoid heavy hammering, and should be kinder on the ceilings below (and the neighbours' nerves).
What worries me is future maintenance. With nails, once you've cut the tongues and got access to a board end you can lever the board up, with care, and re-use it.
If I use screws is there a danger that they'll refuse to budge when some poor person in the future tries to get access under the floor? It would be a pity if the boards had to be butchered to get them up.
If I do use screws, what are the best ones for the job? Would stainless steel be better than zinc, or should I use brass screws?
Many thanks
Ian
p.s.
Whoever lifted the floor previously appears to have gone crazy with a circular saw - taking the edges off both adjacent boards to cut the tongues! I used a pad saw.
Many thanks
Ian
p.s.
