ian
- North Essex
Are you just mopping wet with clean water? You could try a very very weak water with viakal (descaler) mix on a well wrung out mop. A few drops per bucket may do the trick and disolve what may be a lime film on the tiles. If the mop is fairly well wrung out, the solution should not seep too far into the gaps. Otherwise wait patiently for the lime to carbonate a bit more and try this then.
