I have 'reclaimed' the floor bricks and pamment tiles from our vinery, old kitchen, old bathroom and storage cupboards which we're relaying over a new concrete* floor slab and insulation. I have a concrete screed going over wet underfloor heating.
Originally the bricks and pamments were laid on weak dry mix of lime and sand and most came up easily. I'm keen to make it possible to remove, relay or reverse what we can in the future so I'd like lay them the same way. I also want to keep the joints between the bricks as small as possible so the floor looks as close as possible to the original floors. I'm not able to get a clear answer about how laying the floor this way may affect the heating efficiency.
What should I lay the floor bricks on?
* I know it's heresy, let me explain. The building is 3m wide - as I'm not listed to meet building regs I would need >300mm of sheeps wool (or similar) on each wall (room shrinks to 2.4m wide). Upstairs >300mm of sheeps wool would have pushed the roof up by more than a foot (as the head height is restricted). Then there is the vinery to complicate the thermal calcs.
Once I was forced to use Ecotherm solid boards, breathability became impossible - having a breathable floor and non-breathable walls and roof seemed like madness, so we've dry lined the and are leaving the walls with no chemical DPM. Sorry
