Lime
- East of England
If it is an interior grade OSB I'd spray it when dry with a sealer of some sort.Zebra said:I see your point, Lime, about long-term damage to the OSB. Unfortunately, it doesn't look like exterior grade OSB, it looks like interior grade. I can only try to dry it all out and hope that it will be OK long term.
Preferably something that will penetrate the fibres.
Have you considered getting the insulation sprayed in place?
http://www.sprayseal.co.uk/what-is-sprayseal/
Normally I would not think of using it but the sprayed insulation will adhere to the underside of the OSB and to the rafters obviating the need for ventilation of the loft space.
One of the drawbacks of ventilating the roof is that you enable a difference in air pressure on either side of the tape/seal.Zebra said:I've taken the insulation out now, and I can see where all the moisture is coming from. Although I taped and sealed the insulation boards, there were some tiny gaps at the edges where they met the wall. The moisture, mostly from the shower and the kettle, must have been working its way up through these tiny gaps. I'm amazed how bad it is, with such tiny gaps. It goes to show the importance of thorough detailing with airtightness!
I've installed some vents in the east fascia, and am drilling through the firrings to get some cross flow. I will be very thorough in sealing it all up again when I put it back.
If the wind direction across the roof creates a decrease or increase in outside air pressure that is transferred directly to the inside of the loft space.
Almost certainly a differential pressure will exist between the loft space and living area and will put your seals and tape to the test for the life of the roof.
Yes, your life style may need to be altered until a solution is reached.Zebra said:The problem though , as you say Lime, is how to get it all to dry while I'm living in it.
