Hi all,
We moved into a 'newly renovated house' end of last summer. Over the winter, the paint on the front of the property started to peel off in places so when I gave it a prod, large amounts of plaster also came off.
The original part of the house was built in 1883 and extended in the early 1900s. Presumably therefore rendered in lime render.
It looks like the people who renovated the property patched it up with modern cement and then painted over with waterproof paint which has cracked over the winter allowing water in. The cement under the paint has pretty much washed away and is just sand over the original plaster.
The walls are therefore rather damp where the paint has cracked, and lots of bits of the original render have blown.
From what I've been able to gather, the best thing to do to fix it properly is to have the old stuff removed and replaced with lime render and more appropriate paint whilst maintaining all the features.
I've had one quote from a specialist, and am having trouble getting any others to come and give us an estimate.
I'm therefore looking for advice as to what people think is a reasonable amount to have this work done?
