Aidan
- Essex/London
biffvernon said:Mine if definitely Period electrics. No RCD/MCB, just a good ol' fuse box with bits of wire strung through china thingies. You know where you are with stuff like that. But when my immersion heater has split asunder it just stopped working. No blown fuses or other excitements. It has puzzled me
It probably just burnt out the resistance wire thingy.
My fuses were vintage until fairly recently. Now RCD/MCBs in a split load consumer unit, well worth buying. The lights usually trip the MCB now when a bulb goes (non-RCD protected side) , but I'm much more confident that the current would be disconnected if there were ever a serious need. I uncovered quite a few horrors whilst doing it; optional earth connections mainly, sockets wired to lighting circuits. Part P makes DIYing that very verboten now, probably many people will stick with vintage fuse boards; which seems to be achieving the opposite effect to that required.
biffvernon said:The Neutral does go to earth anyway after it leaves your house. There isn't an earth wire running all the way back to the power-station.
I know; there weren't RCDs in those days so it didn't make a lot of difference, providing the earth resistance is low enough to stop any exposed metals bits becoming live. I think it's connected to earth at the local sub-station/transformer.
I heard of someone whose nickname was Earth; he had zero potential.
