Penners
- Suffolk, England
About a month ago our 2-year-old immersion heater stopped working (normal immersion heater fitted into the secondary side of the indirect cylinder). I checked its connections (under the cap) and found that no power was getting through the thermostat, even though the water was cold. I also found that the multi-strand single core connection flex from the load side of the thermostat to the immersion heater terminal post was extremely corroded - it almost crumbled away. However, when I connected up the immersion heater directly to the electrical supply (with the thermostat out of circuit) it worked fine.
So I bought a new thermostat, soldered a new bit of flex on to the immersion heater terminal post, and fitted it all up. Worked fine, patted myself on the back (yeah - big mistake).
Yesterday (some 4 weeks later) it stopped working again, and I find it's the thermostat that's failed again.
Clearly something's wrong that I'm not spotting. I'm hoping that I don't have to drain down and replace the whole immersion heater, not simply on cost grounds, but also because it's an absolute b*gger to get rid of all the airlocks when I refill the system! However, what do you think?
Anyone got any ideas please?
