Flyfisher
- Norfolk, UK
Very true, and I guess good insulation would certainly reduce the heat loss from the fabric of the building, but the walls, floors and ceilings are fixed items and once they are heated they will surely only lose heat relatively slowly (insulated or not) compared with changing all the internal air every 10-20 minutes.
Look at it another way; imagine a house with a heating system designed to maintain an internal temperature of 20C and which has been running for a week or so, so all the walls etc are up to the same temp (the inside faces anyway). Imagine the house has no ventilation. Switch the heating system off and imagine how quickly (slowly?) the internal temperature drops to the outside temp of, say, 5C.
OK, now do the same but in a house with ventilation that is changing the air, say, 4 times per hour. Switch off the heating and within 15 mins the ventilation factor will have replaced all the internal 20C air with external 5C air.
So, ventilation alone will reduce the internal air temp of the house fro 20C to 5C within 15 mins whereas 'normal' thermal losses will cause it to reduce to 5C within . . . . what??? I don't know the answer, and it will certainly depend on the quality of the insulation, but I bet it would be a lot longer than 15 minutes.
If this is correct then surely ventilation must be a bigger factor than insulation when it comes to heat loss from a house? And if it's not correct, where am I going wrong?
