Matt Green
The construction is nearly structural in specification- could that room have been a library?
M.
M.
Clearly that's where I am going wrong; my son is taller than me - I should have been doing this job twenty years ago! Or else wait six or seven years until my about-to-be-born first grandson is old enough.Pford75 said:Small children can be remarkably useful when running cables under a floor
I quite agree about wooden jigs, Nigel.Nigel Watts said:On subject of dowels I have long given up using wooden jigs as I find them insufficiently accurate. ....I found that accurate marking out of the dowel positions on each surface with a marker gauge and ruler, then using a centre punch and pilot drill to ensure the final hole was drilled in the right place gave a better result.
I thought you had him booked to go up the chimney, once you let him out from under the floor.Pford75 said:Perhaps I could loan out my 'cable rat'?
You must have been watching that programme last night on BBC with Ian Hislop talking about how the Victorians' attitudes to children changed, thanks to "do-gooders" such as Charles Kingsley (The Water Babies)Penners said:I thought you had him booked to go up the chimney, once you let him out from under the floor.Pford75 said:Perhaps I could loan out my 'cable rat'?
Has anyone seen or, better still, used those disc-like dowel-marking gizmos with a small spike in their centre? I believe you drill a suitable hole in one piece of wood, then insert the disc/spike in the hole and offer up the other piece of wood. When in the correct position, push the two pieces of wood together and the spike makes an impression in the un-drilled wood and marks the precise position to drill the other hole.Nigel Watts said:On subject of dowels . . . .
Flyfisher said:Has anyone seen or, better still, used those disc-like dowel-marking gizmos with a small spike in their centre?
middi said:The reality is that craftmen of days gone by relied completely on their own ingenuity experience and skill to obtain perfect results. In most cases complicated dowel joints and " secret" mortice joints, such as those found in chippendale furniture, were hand made without the aid of pre-machined gauges, bisquit joiners or brass electric drill guides to get things aligned. Neither did they have monstrous sanders to achieve that uniform finish.
