Flyfisher
- Norfolk, UK
. . . you know, those metal square bars that connect door handles to the door lock.
My job for today (well, one of them) was to fit a set of door handles to a new door. New modern lock and new handles. Simple . . . . except that the handles came with a spindle too short for the thickness of the door so I tried to use the longer spindle that was supplied with the lock, but it was too large for the door handles.
Looking on the web it seems that the standard spindle size is 8mm square (as is the one supplied with the lock) but the one supplied with the handles is 7.4mm.
Although the smaller spindle will operate the lock, it means that there is quite a bit of 'play' before the lock mechanism is engaged, which is not ideal.
At first I thought this could be a metric/imperial thing and that a suitable two-size spindle/adapter would be easily available (i.e. 8mm in the centre for the lock and 7.4mm at the ends for the handles) but I can't find one on the web so perhaps I'm just being over fussy about the amount of play in the handle.
If I'd bought a £9 pair of handles then I probably wouldn't have given it much thought but at 10x that price I was rather expecting a perfect fit.
Has anyone else encountered this issue?
