Flyfisher
- Norfolk, UK
No, but we had an extension built on a previous house and the foundations needed to be two metres, with some of it hand-dug due to access problems. The builders used scaffold boards to shore the sides with bits of 6x2 keeping them apart. Seemed to work OK.FamilyWiggs said:Has anybody done this themselves? The trench will be 1 storey deep and about 3 feet wide, and probably 30 feet in length across the 3 sides of the building.
I suppose you could do something similar between the earth pile and your house wall, using scaffold boards to spread any load and horizontal acrow props, because we already know that the house wall is strong enough, but any such support arrangement would, of course, get in the way of the digging.
But I reckon the design and build of the eventual retaining wall is the bigger issue. The house wall is braced at both ends (and perhaps by inner walls as well) whereas you're looking at building a something new and, as we all know, a brick wall is not very strong when subjected to a pushing force.
I've see retaining walls with metal plates that, presumably, attach to metal rods that extend into the material being retained and, again presumably, attached to some big lump of something (concrete?). But, with your house effectively in the way, I can't see how you could drive a long rod into the mound you're trying to retain.
Your earlier mention of those interlocking steel sections driven vertically into the ground is beginning to seem like a good idea - albeit a rather big one. It's what they've used to widen the M25 around Rickmansworth, as I noticed last weekend, but you should see the size of the machines they use to drive them in! :shock:
Perhaps a 'domestic' version of the principle could be implemented with RSJs driven into the ground with a suitable spacing to accept railway sleepers between them. A friendly farmer with a big tractor and post-knocker might be able to drive the RSJs before you start the digging and they alone would provide some stabilisation while you dig out enough space to insert the sleepers (or those reinforced concrete fence panels?).
But I've no idea how to do the structural calcs that would allow me to sleep at night.
