FamilyWiggs
- Flintshire, N Wales.
Two and a half walls of our dining room are below ground level. The house wasn't built like this, but at some point the yard above was created by filling into ceiling height on 2 sides. This is causing some problems with water traveling through the stone walls and through the lime plaster - leading to mould behind pictures and puddles on the floor after prolonged periods of very heavy rain.
It's time to do something.
We think the answer is to dig out down to the original floor level, put in a gulley at the bottom and create a retaining wall leaving a gap of some 3 feet between the new retaining wall and the original external wall.
I've dug a small test hole, and think the infill is primarily rubble and a lot of what seems to be coke and some slag/molten metal. I'm hopeful of finding an original retaining wall when I excavate, as well as the original cobbles I'm told were there before the concrete yard floor.
Do we need a structural engineer to advise on the state of the walls and how to proceed, given they would presumably have been under considerable lateral pressure for decades? SWMBO is concerned about collapse once the infill is removed. The walls are approx 2 foot thick sandstone. They looked fine internally before we removed the 70's polythene tanking and lime plastered.
I'm more inclined to hire a big digger, take up the concrete yard and start digging.
Advice gratefully received.
Robin
Robin
