We have been using iQ-Therm for few years on a couple of old properties. First the 1.0 system that used the larger boards (much preferred to newer ones) and on our latest project we have to use the new iQ therm 2.0 as the old stuff is all gone. Both systems are v.expensive. Our latest home requires a lot more m2 of external stone walls than we can afford to insulate using iQ-Therm.
To cut costs we have ditched all the Remmers glues and plaster and just use NHL3.5/playsand mix to stick the boards to the wall along with some plastic fixings to be sure. We are plastering on it with NHL2/sand mix imbedded with plastic mesh and skimming with NHL2/playsand mix. Our first walls were finished using this system over 6 months ago and came up great.
After looking at the new iQ-Therm 2.0 boards they seem to be just PIR boards with paper front and back similar to Kingspan TR27 boards that we use on flat roofs. They don't seem to have any calcium injections like the iQ-Therm 1.0 boards. The part that "wicks" the moisture in the 2.0 boards seems to be the lime mortar you use between the boards (like the mortar between bricks in a wall) instead of the injected calcium that the 1.0 boards had in them.
My question to the experts on this forum is will my below system work. It is basically the iQ-Therm system with lower cost materiels:
- NHL3.5/sand mix (glue)
- paper faced PIR boards cut to 1175*125mm with horizontal joints mortared with lime mix and also fixed with plastic fixings
- NHL2/sand mix base coat with plastic mesh
- NHL2/sand mix skim coat
- breathable paint
Anyone see a problem with any of the above? Any help/advice on this would be.very much appreciated.
- breathable paint
