Penners said:MdB - is there any point in equipotential bonding if the bathroom water supply runs in plastic pipe? Do the regs have anything to say about this?
Equipotential bonding is acceptable to the regs (when done to the regs) and it isn't necessary to bond everything metal in the bathroom if connected by plastic pipes. For example, if you have plastic pipes everywhere but a metal bath, metal taps and an electrically powered metal towel rail then it is only necessary to connect the towel rail to the earth wires of circuits entering the bathroom. If the towel rail became live for some reason, then touching the taps would be perfectly safe as there is no route to ground for the electricity. The thickness of earth wire required for earth bonding is given in the regs and depends on the type of earthing system you have.Flyfisher said:However, I doubt it, alone, would comply with the wiring regulations and I would guess that if you have plastic water pipes then a big earth wire back to a known good earth would be also required (but I'm not up to date with the latest regs and, besides, I'm not a qualified electrician so this is all conjecture!).
One advantage of an electrician over an building inspector is that they are more likely to advise you and help you fix anything non-compliant - rather than tell you it isn't right and leave. You would need them 'on your side', perhaps you could do the setting up and pay them to make the final live connections, check and certify the lot?Flyfisher said:Re: certification: Yes, I'm sure BC would charge, but so will an electrician. I don't know which would be cheapest; it'll probably depend on the extent of the works to be checked/inspected.
