Flyfisher
- Norfolk, UK
I believe they are rated at 200Mbps as they support full-duplex operation, i.e. 100Mbps in both directions simultaneously - theoretically. But it's really just marketing guff and such speeds are almost certainly unobtainable in any practical installation.MdB said:Show me a 200Mb powerline adaptor which has anything other than a 100Mb ethernet connection on it. (The Belkin one doesn't count as it is rubbish.) Real life speeds are very approx 50mb YMMV.
Although networking has been made very easy these days, in the sense of plugging and playing, implementing a performance-critical system with guaranteed speeds and throughputs is a whole different ball-game. A wired system with network 'switches' is trivial to implement but actually incredibly sophisticated in its operation, meaning that a two PCs can exchange a huge file (e.g. stream a video) while a third PC can still access the web at full speed. With a wi-fi system, all the data transfers have to compete for the same bandwidth and this significantly slows down the overall speed of operations - usually by far more than just the sum of all the data transfers - for all the devices on the network.
It's the same with a powerline network but with the added complication of mains-borne interference causing additional slow-downs as the powerline units have to resend data many times before uncorrupted data finally gets through.
In essence, a single PC used mainly for email and web browsing will work perfectly well with wi-fi or powerline networks and using a wired LAN will give little or no increase in performance (because the broadband connection is the bottleneck). But, add more PCs and/or other devices to the LAN, start copying files or streaming music and/or video across the LAN and the limitation of wi-fi or powerline will quickly become apparent. Copying a file (as part of a backup regime perhaps?) slower than possible might not be a problem but stuttering video or music playback is unlikely to be acceptable.
Horses for courses indeed.
