Conversely, Conserver, the addition of a concrete floor + DPM into an old house can cause damp in the walls as the DPM is unlikely to have been fitted through the walls. The DPM stops moisture from evaporating from the floor which gives you a nice dry floor but increases the water content under the floor and hence under the walls as well. This is what had happened in my house and led to failed plaster on the bottom 200mm of all the internal and external walls. Often removal of the concrete floor + DPM and replacement with limecrete so the floor can breath is a better solution.
Having said that, we have just fitted a new concrete floor + DPM in the house as we have also replaced the walls so could fit the DPM underneath both the floor and the walls. We have also left a large gap next to the old walls which will be filled with limecrete so as to hopefully leave a large area for evaporation.
