Perhaps I'm being obtuse ?!?-Penners said:Each to their own, but as Worms confirms above, I've never found it necessary to to do more than pop in a short screw or two, in order to keep floor-standing units in place. As to the advisability of screwing into Thermalite blocks, surely this depends on what fixings you use.AMc said:Most over the counter units I've seen have 2 screw fixings which I wouldn't trust fixed directly into thermalite block. By fixing battens then ply to the battens and then plasterboard then the units to the ply through the plasterboard you spread the weight of those two original fixings across a much wider area.
Obviously the final decision is entirely up to ragingbull. In response to his request for ideas, I can only explain what I would do.
Personally, I wouldn't hang wall cupboards, the ones that go OVER the counter from 2 screws fixed into thermalite concrete blocks.
There is no need to worry about base units, the ones that stand on the floor under the counter
