frednelson203
- Suffolk
I have an 18c property which has had several attempts over the past 4 years at resolving damp problems on an external wall next to a fairly busy road. Three years ago we had all of the plaster removed inside and out and had it replaced with lime putty and painted inside and out with lime based paint. After the first attempt failed we tried again and included an injected dpc and a french drain
We repeatedly get flaking plaster and salty deposits despite all the work being done by reputable builders and under the supervision of a local well respected surveyor
I am about to buy a dehumidifier to try to solve the problem and will probably take off the interior plaster up to about 2 feet for a year to see if we can dry out the wall
Does anybody have similar experences and therefore helpful advice
