TimHardusty
- Portland, Dorset
Having moved in to our 17th century G2 listed Portland cottage a few months ago, we have just started on the redecoration.
First room is the dining room, which was the downstairs room of one of the two small cottages joined together sometime in the past. We stripped the wallpaper - which was vinyl and, I believe, limiting "breathing" from the walls - to find various areas of damp.
Much of it has dried well now it is exposed to the air - might have to hack off some gypsum plaster repairs and lime plaster it if I get brave - but we were left with damp cupboard - 85% RH at 18C.
In this room, an old front door was blocked up sometime long long ago. At the front, it has been infilled with small stones, and behind that I now know, large stone blocks.
Investigating the damp, I found a hole in the back wall of the cupboard, so I started exploring, and after removal of various wood linings and newspaper "stuffing" (1983, so no interest there) I found the rotting remains of an old door frame - or timber infill - around the large stone blocks that had been used to block the doorway. I hacked away, and have now removed all of this rotten wood.
There is an issue with the timber across the top that I need to deal with, but it is only there to provide something for the boarding that was at the top of the cupboard to be nailed to; nothing structural, thankfully.
I have removed as much of the paint that had been applied to the stone - I don't think it was limewash, more likely a "mould resistant paint" - so it can now "breath" better - and hopefully time will tell whether it becomes a fundamentally drier place.
To the left of the cupboard door modern plasterboard had been used...this was damp, and is now removed. Not 100% sure why it was damp, but I'm clinging to the hope that it is trapped moisture due to the vinyl-coated wallpaper and/or lack or "breathability" of the modern PB that had been stuck over the stone.
My plan is to rework the area to make a cupboard again, and I'm debating whether to batten and board it (with foil lined PB?) or maybe have a go at lime plastering it, or maybe try wood-wool board with a lime plaster skim?
But the point of this post is that I am unsure what to do to fill in the space left empty by the now-removed rotten wood.
- treated timber, and a skim of some sorts?
- modernvbricks, mortared in - but lime mortar or modern mortar?
- or Portland stone mortared in?
- half tempted to use expanding foam, but that's not right of course!
Can you let me know what you think please?
