LadyArowana
chippy1 said:LadyArowana said:We had horrible condensation issues in the vaults, even with DG units in the windows. We still had horrible condensation issues with the windows and door open. Running a de-humidifier has stopped it!
Hi,
Please can I ask which type of de-humidifier you use? I've read that Compressor Dehumidifier work better in warmer houses and Desiccant Dehumidifier are better for colder houses? Any advise would be helpful, thank you
I actually run two de-humidifiers. The one in the vault is an old one, reasonably heavy, metal case, has coils at the back behind a screen, they get cold and water runs down into a tray attached a hose as there’s a floor drain. The new one, which works in a similar way but is lighter and quieter is a Meaco. Currently running that on a reservoir. Planning to put it where it can drain into the washing m/c waste if we are away for a while. https://www.appliancesdirect.co.uk...cbeLWxVavGFFa-FrRrePKptCvfHpMAwxoCohgQAvD_BwE
