jocelyn plummer
- North Norfolk
We are finding that condensation is quite a problem. Not surprisingly really with a plastic wood effect floor, plastic window, plastic tongue and groove half way up the walls.
What is interesting is that the oil from the bathroom vinyl paint that was used previously, is running down the walls as well as the moisture droplets.
Anyway, I am obviously going to investigate behind and remove the plastic tongue and groove, in order to repaint with a breathable paint.
How do I get the vinyl paint off the walls ? There seems to be only one coat, with plaster behind-- discovered when I put a cupboard up.
Then I will replace with wooden tongue and groove, but should I wait until I can afford to replace the placcy window and flooring as well, or will my part measures and time and effort make a significant difference.
The window budget is really best left until next year when I hope to do all the others as well.
