Yes Grants whats that.
Dracer said:Well all brick but just the chimney; I know its difficult to explain with just text.
Think of a brick chimney built on the outside wall of a house, bodged and re built many times with a capping on the top and re flashed and vented by my builder.
Dracer said:Gareth as mentioned earier the chimney has expandedmetal stuffed in and cemented.
but sorry all it is slightley wider at the bottom and all tree sided exposed.
It also has some type b in it too
So the chimney's all brick, with three sides of it exposed to the outside (that bit you've answered), and it's not tied to the rest of the house which is, for the sake of argument, another material that you don't wish to reveal?
Does the chimney get wider at the base or is it straight up and down? Does it go straight into the ground as brick or is it on a plinth? is it exposed brick right down to the ground or is any of it painted or rendered?
Gervase said:The IP addresses of posters are available to moderators, so it would be a relatively simple matter to resolve. Meanwhile, there is a strong whiff of rodent hanging about...
