Pics would be very useful and not difficult to put on. Press the upload attachment at the bottom of a new post, click on Browse... select your picture.Dracer said:No pics but would not know how to send them.
middi said:a REALLY knowledgeable builder will put you on the right track ,
Lime said:From what I've read of the problem chimney I know it is made of brick in part, capped and damp, not a lot else.
Details appear to be sketchy as to what it is attached to and the description "its all brick up to 5 foot" without much meaning and lacking clarity.
However "Do you sugest a chmical damp course up and around and through?" suggests you are either taking the Mickey or you need to change your builder.
Dracer said:Lime said:From what I've read of the problem chimney I know it is made of brick in part, capped and damp, not a lot else.
No not the mickey chemical inject through the section and up the chimney against the wall
