yamin
- Alcester, Warwickshire
Hi
Can anyone proffer an opinion? 18 months ago we had an old chimney stack removed because the 'bricks could just be lifted off' (have since learned that this could just be the way lime mortar works but anyway). Flashings etc were repaired and the chimney stack below, which had been damp, began to dry out, albeit slowly! Fast forward 18 months e and in the summer (haha!!) we had a woodburner fitted into the old fireplace on the ground floor. This does not use the chimney as such, but does use the chimney as a space through which to route a double skinned flue. 3 months on and we've suddenly noticed the chimney is sodden again! Its half way down the chimney breast on the first floor of our two floor cottage. We have checked the roof and there does not seem to be a leak up there. A well recommended and 'old building sympathetic' builder came today and had a good look. He seems to think that the cause could be that the woodburner flue, now we're using it a lot, is, despite being twin skinned with insulation between, still getting warm enough to draw cold air into the chimney (remember, no stack) and this is condensing in the upper part of the chimney and causing the damp problem. I have read about this kind of thing before and think it sounds logical. What do you think? And as for solutions - his suggestion would be to lift a few tiles, and backfil with vermiculite to 'insulate' the twin skinned flue so that the warmth does not draw in cold air. Does that make sense? I also wonder if an air ventilation brick at cround level on the first floor in the chimney breast might help??? Either way he says we need the plaster pulling off the chimney breast in order for it to dry out properly now. Its totally sodden!
Thanks for any help and advice
Abi
Abi
