About a month ago we moved into our new house - it was built in 1904 and is a 5-bed semi in the Davenport Park Conservation area in Stockport.
It was a tortuous process getting through all the surveys and as part of the conditions on the mortgage certain works need to be done during the first 6-months. I'm OK on all of these (tiles, rainwater goods, gulleys, wiring etc) except one. Purely because the house is 104 years old and has cavity walls - the surveyor has insisted that the cavity wall ties will be decayed and need to be replaced - there is no evidence that the walls are distorted - my conversations thus far with specialists say that they will need to drill through the centre of the bricks (2.5 per sq metre to meet modern building standards). The house is half rendered but the bottom half will be disfigured by this process - one alternative would be to drill from the inside out but this would not be possible everywhere - e.g. in the kitchen where fitted units are in the way and it would cause a great deal of mess. I can see no need to this- what do you think?
My only fall-back position was to get in touch with a surveyor recommended by Stockport Conservation Officer who is coming to look at the house on 15th May.
Any ideas would be much appreciated. Clive
