We are renovating an old stone barn, with a tired corrugated tin roof. It is laid straight on to the rafters. I want to renew the tin, but need some help with ideas.
- is there any type of tin which you would recommend?
If not tin then Heaven forbid, but is Marley's Eternit range any good? I like the thought that they produce a range of muted colours to try to be sympathetic to the setting.
- if tin, we are thinking of the type which is coated with plastisol, to extend its life; any thoughts?
- we want to relay the roof on plywood sheeting: any recommendations on type or supplier - marine ply for durability?
It is a windswept site, looking out to sea. We also want to lay a vapour barrier between the tin and the plywood. Any thoughts on what type to use?
Finally, we will need to insulate the rafters - any thoughts on which product? I thought rigid foam but don't know which product to use. Kingspan?
Thanks for all your help.
Ross
Ross
