Flyfisher
- Norfolk, UK
. . . which only makes the Mona Lisa even more impressive.JoceAndChris said:The misleadingly named "daVinci" brush in question is a scabby pig's ****hole of a thing . . .
Flyfisher said:. . . which only makes the Mona Lisa even more impressive.
outlaw said:The brush is merely the tool for applying it, it will only do what you to tell it,... dont press down too hard.
True enough, but I find it easier to paint cleanly up to a single edge than to two simultaneously. When doing the moulding if you only have to worry about getting, say, the outer edge clean, then you can relax a bit about getting some on the panel. When you do the panel you only have to worry about getting the edge with the moulding right etc.JoceAndChris said:However, just as you don't want green on your cream panel neither do you want cream on your green moulding.
Cloudscape said:emulate other types... So you switch (if you can).
Nigel Watts said:True enough, but I find it easier to paint cleanly up to a single edge than to two simultaneously.
Being able to paint up to a reasonably straight edge is especially valuable for doing sash bars, which would otherwise be a complete pain.
Bet you can't say that with a mouthful of crisps.Moo said:Sashibike
My sage advice would be: don't get distracted by (very pretty) cats.JoceAndChris said:If anyone has any suggestions for driving success please tell me, I'm especially interested to learn why you/ friends/children failed, if you failed.
JoceAndChris said:I think you're right, you try to switch and adjust your speed/ weight/ direction. But your preference or skill with regard to icing cakes or chopping logs reveals your natural type.
michael said:To get the perfect straight line finish without bleeding you would probably need masking tape (well sealed at the edge) and a paint spray gun.
Cloudscape said:But maybe that's part of learning skills - adjusting yourself to suit a task? Gradually you learn how to arrange stones to make a wall, and develop the understanding and control (and presumably the muscles!) to do that work. Or someone 'thrusty' learns to do something delicate, such as tying fishing flies, or jewellery making.
OK... some try and fail. But most of us must have the potential to be more than one type, even if a task seems daunting or impossible at first.
Cloudscape said:JoceAndChris said:Your paintwork probably looks every bit the part... it's just that you, like most people, tend to see the flaws in their work, rather than see the work in its entirety.
