During some of the trials of getting our heat pump heating working effectively one of the engineers accidentally pressed a button on the control panel. In addition to not having a warm enough house we started to not have any hot water in the morning. It took 3 of us to realise that he'd disabled the timer program that switched from heating to hot water mode overnight. I was not impressed.tobydog said:We recently had a new blending valve fitted by another plumber (appointed by the manufacturer) and he may well have turned off this tap and failed to turn it back on again.
Then when I adjusted the clock for GMT this autumn I did the same thing and spent 2 days wondering what was broken before I realised it was my fault - thankfully I hadn't called them out
Hope it's simple to sort. It is worth labelling the valves/stopcocks or drawing on the wall behind them to indicate their function and correct operating positions. Plumbers etc. tend to miss this step, then a new one has to work it all out from scratch and you yourself have no clue. I had to spend a few minutes puzzling the correct positions of the shut off valves on the water softener after I'd serviced it.
