88v8
- Glorious Gloucs
Nigel Watts said:My system is about 10 years old and has not been altered, nor does it have any tanks in the attic, being fully pressurised. What has happened over the 10 year period however is the taking off of radiators for decorating and subsequent replacement. Clearly when this happens water is lost and has to be topped up.
And so the water treatment is diluted ....
Before they come round I'd buy a Fernox test kit, available through that link I posted or perhaps from a plumber's merchant, and check the water yourself by draining off a smidgeon.
If you're under-dosed, that wil tell you immediately, then you'll know you've found the probable cause.
Otherwise, draining & flushing might remove the adverse symptom - sludge - without you being any wiser as to the root cause.
With wall-mounted cast-iron rads, they can be pivoted down from the wall without disconnection from the system, thus no water loss. I guess a few years to late for you to know that...
Ivor
