Nigel Watts
- London N7
Having had a heating engineer in to fix it in January the problem has come back.
Boiler fires up when it should but goes off after about 30 seconds. A few minutes later it does the same, ad infinitum. Result: water in tank and radiators is tepid at best.
I think it must be a fault in the water circulation system between the boiler (ground floor) and hot water tanks (we have 2 on the 1st floor). There is a pump next to the boiler which seems to come on as it hums and vibrates. There are three electrically operated valves on the first floor on the pipe coming up from the boiler, one on the input to the coil on each tank and the third at the start of the central heating loop. All three appear to be free and working. I experimented with opening the tank valves using the manual override but it did not solve the problem . The system is fully pressurised and does not seem to have air in it.
The engineer is coming back tomorrow, so I would like to know what to ask him. My guess is that the problem lies either with the pump near the boiler or inside the boiler, e.g. a faulty thermostat, by I am no plumber. Any ideas?
