In order to lime plaster my bedroom this weekend I have been removing all of the old plaster that has been applied through the ages: from old lime (only the loose stuff) to modern skim plaster. I wasn't originally intending to discover the fireplace that I knew would be there, but the plaster just kept coming off....! Call me inquisitive.
I feel really privileged to be the first to see this after being hidden for so many years - the small joys of owning an older house!
Anyhow I'm now left wondering what my options are...
The room is my main bedroom. It is not a large room and the bed usually goes against the fireplace wall. Therefore a working fire would not be useful. However the wall you see to the right is a modern stud partition, which, if I gain consent for my kitchen extension could be removed in a year or two. This would make the room much larger (original size), and therefore benefit from the fire.
So my options seem to be:
1. replaster and forget about it;
2. cover with plasterboard and plaster over that ready to be rediscovered in a year or two;
3. continue removing plaster and plaster around it to create a feature fireplace;
or 4. restoreit to its former glory as a working fire. (Should be possible since air is being drawn, chimney still in place etc.)
What are your thoughts? What condition is it in? How much effort would be involved in restoring it? What should I do?
What are the regulations for existing fires? Could I start using it now, or is the stud partition too close?
Finally, I was a bit surprised at what I found. I presumed there would be a cavity behind the brick all the way to the floor. In fact the cavity is only as low as the first layer of bricks you see. Is this normal? Is it designed to take a fireplace protruding from the wall which directs smoke into the flue? As you can tell, I know little about fireplaces!
More photos available at:
http://picasaweb.google.com/ajbaker/BedroomFireplace
If anyone is interested I could post more photos of this, my first DIY project in lime...
Oh, and once again, a huge thanks to those who offer their thoughts and advice on this board. I really appreciate people taking the time to share their valuable experience and knowledge.
Andrew
Andrew
