gothiceye
- Shropshire
Hi,
We've had a leak from our shower on and off for some time, but have finally plucked up the courage to make an inspection hole in the plasterboard wall which seperates it from the spare room... and are definitely wishing we hadn't! Owing to the close proximity of the shower to the toilet, the builders had apparently had the bright idea of building the wall around the shower tray... with part of it sticking through the wall. What little plasterboard they used to create the wall on that side extended only partway down the wall, with the rest of the tiles hanging on by what looks like sheer willpower..... :shock:
Anyway the mount for the shower tray is rotten, so will have to come out, as will most of the wall so we can repair it. We have however, through more investigation holes (most of our house which isn't original seems to be mainly built of plaster board!) discovered the old fireplace for upstairs behind the back wall of the shower, so we are planning to move the bathroom wall along when we rebuild it so that the fireplace can be revealed, as a decorative feature, even if we cannot use it (since the main chimney has recently been lined).
Question is... moving this wall will mean that we need to rethink the arrangement of the bathroom, and we are looking at moving the placement of the fittings to accommodate this. What do we need to consider in order to do this?
Additionally - when we remove the rest of the plasterboard to reveal the fireplace, it looks like we will need to reroute a ring main or similar and a water pipe (and remove a ton of rubble), which have all been run round the back of the plasterboard (?) :shock: .... any advice?
