Morning all,
We're currently restoring an inglenook in my 17th C Farmhouse. I'm looking to put in a Wood Burner, which will sit on Pamments. My builders are suggesting a concrete base within the Inglenook, to add support to the large heavy Stove, but also to stop damp drawing up through the floor, which is currently just earth. We'll then bed the pamments in with a 7-2-1 (sharp, lime, cement) mix.
It's the words "concrete base" that I'm not keen on, but I don't mind the use of modern materials used in the right fashion. Obviously, a modern wood burner is not a traditional item, and will be much hotter than a 'tradition open fire'.
I just want to make sure we're doing the right thing, before anything becomes irreversible!
Your help, as always, appreciated!
Dan
Dan
