Flyfisher
- Norfolk, UK
Soakaway info: http://www.waveney.gov.uk/Planning/Bldng+Control/Guidance+Documents/soakaway_guidance.htm
Google "soakaway" for loads more.
Thanks for this, will stop being lazy and do some research on soakaways! If a rain butt isn't the answer I need to sort this out.Flyfisher said:Soakaway info: http://www.waveney.gov.uk/Planning/Bldng+Control/Guidance+Documents/soakaway_guidance.htm
I've found it quite interesting* and productive to walk around the outside of our house (and scaffolding) during rain storms and really see how the rainwater is being handled. I've spotted, and easily fixed, a number of problems that were only really obvious when it was pouring with rain.jaykayem said:P.S. Flyfisher, by "rotten day", I meant the weather, which was horrendous!
Flyfisher said:*How sad is that?
Fair point. I probably wasn't using the term in an entirely correct way as I'm not really sure when a 'ditch' dug around the house to ventilate the lower wall actually becomes a french drain. When it's filled with gravel and a land-drain pipe perhaps?Lime said:I don't think it has been said, so I'll say it.
Lowering the outside ground level is far better than installing french drains.
Flyfisher said:Filling with coarse gravel would make it very free-draining but would also retain a fair amount of moisture. I've even though about some sort of 'grille' , which might help keep it clear (although not eliminate the need for regular clean-outs) but, apart from the expense, I don't think it would look particularly good.
That sounds more like it, although I'm not entirely sure of the design you described; I can't see railings sitting over a ditch. But I like the general idea. I bet it would be an expensive job these days though. I should look for a local blacksmith, perhaps, and make some enquiries.Lime said:In the olden days (victorian particularly) a blacksmith might have been asked to construct a small set of railings built in the shape of a quadrant to sit over the ditch.
The issue I've not really resolved yet is how to 'dress up' the trench? I presume leaving it open would be best for ventilation but it would require regular cleaning to prevent it silting up over time. Filling with coarse gravel would make it very free-draining but would also retain a fair amount of moisture.
Flyfisher said:That sounds more like it, although I'm not entirely sure of the design you described; I can't see railings sitting over a ditch. But I like the general idea. I bet it would be an expensive job these days though. I should look for a local blacksmith, perhaps, and make some enquiries.Lime said:In the olden days (victorian particularly) a blacksmith might have been asked to construct a small set of railings built in the shape of a quadrant to sit over the ditch.
The problem, as Lime has observed, is that anything you put over the trench carries the risk of reducing the circulation of air, which is vital to its proper functioning as a damp cpntrol measure.Flyfisher said:I was thinking more of something flat.
Flyfisher said:Thanks for that Gareth (is that your own sketch?). I think that sort of thing would be a bit too intrusive though (would it require LBC I wonder?).
In which case I think I may have seen some of your sketches on toilet walls.Gareth Hughes said:I think my sketch exaggerates the size
