skier-hughes
- Staffs, UK
Excellent one Gareth, and also very easy to visualise.
Nemesis said:Try convincing the local BCO though...
Sorry, do you mean the document or the BCO?Nemesis said:Aren't they made of wood though?
Gareth Hughes said:Small diameter holes drilled horizontally (from the inside face) to half the thickness of the opening light frame, meeting similar holes drilled up from the underside of the frame, making an inverted "L" shape in cross section which bypasses any draught sealing between the frame and the opening light. Our BCOs have accepted it.
(sorry, it's a bit difficult to describe without a drawing)
From http://www.thermsaver.co.ukI wonder whether they do, in fact, recover more energy than they expend
I guess it also depends on the cost of the input energy in the system - if you are heating with home produced logs, then the 2000 Kw recovered might be worth less than the 800 Kw electricity used and at the other end of the scale if you are heating with electricity there is potentially a large saving. I'm not sure where the trade-off would be at the moment for those on gas or oil.As a guide, a typical system operating in Scotland from September to May continuously at 100 cubic metres per hour, would recover 2000 kilowatts with a fan running cost of 800 kilowatts, showing a net saving of 1200 units
