Hello,
I recently moved into a Victorian house (1850 - 1860) & discovered the exterior stone work needs more attention than I imagined so I'm hoping this forum can help guide me in the right direction. I'm doing this type of work for the 1st time due to budget so advice on what approach and materials I should use would be of great help. I have also done a certain amount of research but thought I'd keep my theories to myself for now.
I'll try and keep this simple by outlining each problem and attaching a photograph to help with any feed back people may have.
Problem 1.
The paint at the base of two sandstone pillars has peeled and flaked taking away the outer layer of stone with it. How do I prevent the crumbling and strengthen and re-build the surface?
Problem 2.
Some stone details have broken off and others will have to be removed. Is there a way of gluing these back on?
Problem 3.
There are cracks in the stone ledge above the door. What would you recommend I fix these with?
Problem 4.
The paint on the window cills has peeled and the stone surface is worn and un-even. What would you recommend I do to make this look good again?
Problem 5.
The wall edge has gone. Can I reconstruct this with a lime mortar?
Problem 6.
The render has deteriorated. Should I take this back to the base and render with a lime plaster?
regards
Roger
Problem 1.
Problem 2.
Problem 3.
Problem 4.
Problem 5.
Problem 6.
regards
Roger
