skier-hughes
- Staffs, UK
I thought Biff just made the frames and installed sealed unit double glazed panes. I amy be wrong
skier-hughes said:I thought Biff just made the frames and installed sealed unit double glazed panes. I amy be wrong![]()
If you want to glaze a window with glass that looks a bit wobbly and distorted - hence looks old - use horticultural glass. It's cheap too!Ian Bond said:hand made wobbly glass
Penners said:Ian - the horticultural I've used in the past has looked quite appropriate in a period window. Frankly, I think that any glass that isn't "perfect" does the job fairly well. It all depends how fussy you are!
:wink:
(Oops - I shall get into trouble with Moo for that.)
Ah, this is where it gets complicated as float and plate are not the same.Ian Bond said:Or go extra posh, and pretend I've got polished plate glass (like some of the grand country houses) but use ordinary float glass instead![]()
Jack London said:Before thrusting out my head, my senses, automatically active, had told me there was nothing there, that nothing intervened between me and out-of-doors, that the aperture of the window opening was utterly empty. I stretched forth my hand and felt a hard object, smooth and cool and flat, which my touch, out of its experience, told me to be glass. I looked again, but could see positively nothing.
"White quartzose sand," Paul rattled off, "sodic carbonate, slaked lime, cutlet, manganese peroxide--there you have it, the finest French plate glass, made by the great St. Gobain Company, who made the finest plate glass in the world, and this is the finest piece they ever made. It cost a king's ransom. But look at it. You can't see it. You don't know it's there till you run your head against it.
biffvernon said:Jack London said:the finest French plate glass, made by the great St. Gobain Company
