Gervase said:Can anyone be a knight in shining armour?
A client of mine is getting hell from building control. I was trying to be sneaky, doing the work on her place as 'repairs and reinstatement' rather than conversion or renovation, so that building control wouldn't need to know what was going on. Included in the programme is a limecrete floor and three-coat lime render with roughcast on the outside, and three-coat haired lime plaster on the inside, with clay board ceilings and thermofleece insulation.
Unfortunately the client has engaged some local builders to put an extension on the side of her place, and they've called in building control to OK the footings (as per normal), and the wretched pedantic muppet from the council has now started demanding a say over the internal work and the rendering (which, technically, he has a right to do, as I was being a little sneaky).
The upshot is that he's demanding that the rubble stone walls - a metre thick- be dry-lined and celotexed rather than lime-plastered, and is also threatening to demand that the render be replaced with cement if we can't prove it's waterproof! Aaargh! And, in passing, he wants to know the U value of a metre thick rubble-stone wall, and of the limecrete.
It's a grey area - technically I'm led to understand that the only area he's currently supposed to have a say on is the floor, but the new Part L regs can be applied to the whole building if more than a certain percentage of the wall is being changed or an extension being built.NT said:What give this person the right to a say in any of the work bar the floor?
NT
Gervase, I admire your wish to try and establish some firm precedents for the future, for the sake of everyone with an interest in period property. But at least you've got a resolution here without getting your tailfeathers burned.Gervase said:The issue has now been resolved. In case you think that means that a binding precedent has been set, be still your beating hearts. I’m afraid the resolution is a classic piece of fudging – but a relief nonetheless
The first period property that I worked on was about 33 years ago. It was a tiny Essex timber-frame cottage, C15th, whose foundations were little more than two courses of bricks below ground level.biffvernon said:a traditional stone cottage with no significant foundations, the extension was a light weight timber frame but still needed groundworks and concrete sufficient to support a modest multistorey carpark.
