Penners
- Suffolk, England
DaveBrigg - have you tried tightening the nut before you try undoing it? I realise that you've probably destroyed most of the nylon part by now, but presumably you can still get a grip on the metal sleeve with stillsons.
Sometimes a generous soak with easing oil, followed by a good heave in the tightening direction, will crack the corrosion sufficent to be able to undo a frozen nut.
